switching to posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2003, 10:29 AM
camino_man's Avatar
go like he11 machine
Post switching to posi
hello again. im sort of new to the concept of rear ends. my el camino has a open differential i know. i want to change it to a posi. is this possible without buying a whole new rear end (you know, case, gears, axles, etc.)? or can i just buy differential gears and replace the ones in my el camino? i dont know what my gear ratio is but i think its fairly high. my plan is to put in a 3.73 gear, would changing from a high gear to a lower one effect changing to a posi? sorry so many questions. thanks
Old 06-08-2003, 12:04 PM
Rubberman2003's Avatar
Post
Dont quote me but i think you can buy a posi unti from Jegs or Summit, i think its just some gears or something to replace ones in the differenctial....not 100%
Old 06-08-2003, 12:08 PM
BOBCRMAN@aol.com's Avatar
Post
You will need to buy a 3-series posi-unit(Differential) there are various manufacturers, Auburn, Eaton or the stock GM types. Then you get a 3.73 gearset and have a rearend shop install them. you pays your money and you makes your choice.
