-   -   switching power steering gears (http://www.hotrodders.com/forum/switching-power-steering-gears-12789.html)
Impala Stuart 03-24-2003 05:35 PM
I have a '69 impala and it runs ok. I wanted to soup it up abit. One area I was thinking about was to go from the current power stearing gearbox to a later model one. Can this be done easily? What are the gearboxes which will work on a '69 impala? I have a 350 in it.
toymobile 03-24-2003 05:40 PM
any GM car box will bolt in up to 1979, 1980 went metric, box off cutlass or MC should give you some better turning ratios. good luck. JF
Impala Stuart 03-24-2003 06:27 PM
Better turning as in tighter steering? and fewer turns from left to right?
toymobile 03-25-2003 03:49 PM
10-4 check pitman arm legnith also, shorter the better, Good Luck JF
[ March 25, 2003: Message edited by: toymobile ]</p>
