switching power steering gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2003, 05:35 PM
New Member
Post switching power steering gears
I have a '69 impala and it runs ok. I wanted to soup it up abit. One area I was thinking about was to go from the current power stearing gearbox to a later model one. Can this be done easily? What are the gearboxes which will work on a '69 impala? I have a 350 in it.
Old 03-24-2003, 05:40 PM
Post
any GM car box will bolt in up to 1979, 1980 went metric, box off cutlass or MC should give you some better turning ratios. good luck. JF
Old 03-24-2003, 06:27 PM
New Member
Post
Better turning as in tighter steering? and fewer turns from left to right?
Old 03-25-2003, 03:49 PM
Post
10-4 check pitman arm legnith also, shorter the better, Good Luck JF
[ March 25, 2003: Message edited by: toymobile ]</p>
