switching standard to automatic 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2003, 09:14 PM
New Member
Post switching standard to automatic 350
Not sure if post should be here or in engines. Would like some help on what is needed to change a 350 motor with a standard transmission to an automatic TH350. Any help would be apreciated. Thanks <img src="confused.gif" border="0">
Old 03-01-2003, 06:21 AM
Thumbs up
Provided what trans you presently have (Saginaw or Muncie M-20 or M-21) this is a bolt in swap. Just pull everthing from the 350 and get a flywheel (or flexplate) and a transcooler. If your have one of the above transmissions your present crossmember and driveshaft can be used. This is an easy swap to do and you shouldn't have to modify anything. Hope this helps and happy motoring.
Old 03-01-2003, 01:58 PM
Post
don't forget to remove the input shaft pilot bushing from the end o the crankshaft
Old 03-01-2003, 06:01 PM
New Member
Post
Thank you for your inputs I appreciate it very, very much
