If you run relays with your existing lights it should make a big improvement,it is fairly EZ to do click on this for an EZ explanation: www.watsons-streetworks.com/current_topic.html
Here's something you might want to read before you buy any more H-4 bulbs. Also - relays work best. You can run wiring that will handle the 55 or so watts rather then the 16-14ga usually supplied in a kit.
![]() Oh - and the Sylvania super bulbs - they are, but you will give up lots of their life expectancy for that extra brightness. That's from personal use as well as many reviews I've read. Dave W |
The H4 is only the bulb.
The headlamp optics (reflector, lens etc) is critical to correctly focused lamp. And of course proper aiming. These work great. Hella 70 477 is the 7" round assembly. Not cheap but ---- All other parts of electrical system must working correctly especially the alternator. Wire size to the lamps #14 or larger. Good grounds. Quality headlight switch. Quality dimmer. I see several internet sites that sell them. Also try e-bay. vicrod |
Well I have the shop on weekends for the next few weeks so I think I'll try the relays and heavier wire first, then if there is some improvement I can just add the Sylvania lamps. Fortunately the lens are glass.
| How good are pro comp cylinder heads | automedics | Hotrodding Basics | 49 | 04-22-2013 05:40 PM |
| Yamaha Virago 750 Good Starter Motorcycle? | mgold | Hotrodders' Lounge | 25 | 12-21-2009 06:38 PM |
| Good Tech School in Atlanta? | mgold | Hotrodders' Lounge | 0 | 09-16-2009 08:12 AM |
| Good Place to get a Trans Built? | YB2fast | Transmission - Rearend | 6 | 07-07-2009 02:41 PM |
| Good Hotrod Cam for 302 | RetroJim55 | Engine | 11 | 11-07-2008 02:00 PM |
