synthetic enamel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2007, 07:30 PM
synthetic enamel
Im painting my car with synthetic enamel and I bought the primer-sealer that goes under it.Do you use hardner in the primer or just in the topcoat?
Old 04-10-2007, 07:49 PM
EDIT-
Mistaken post
Old 04-11-2007, 04:02 PM
Countilaw's Avatar
Cox Custom Cars
Read the P-sheet. Some sealers don't need an activator. Need more information to better answer your question. What brand sealer is it.
Old 04-11-2007, 05:49 PM
john deere buff primer-sealer
Old 04-12-2007, 06:19 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Synthetic enamel is the bottom of the paint chain.
It's far less durable than acrylic enamel which most won't use.
You'd be better off using anything instead of synthetic.
As far as I remember, synthetic enamel can't use a hardener,
that's why acrylic enamel replaced it, acrylic enamel can use a hardener.
I thought that went away in the early 70's.
Old 04-12-2007, 06:59 AM
I bought the paint,the primer-sealer,the reducer,and the hardner,all off the same shelf,all the same brand (it's the one we're not allowed to mention on this forum anymore) J D B B
Old 04-12-2007, 09:25 AM
jcclark's Avatar
The Penny Pincher
If it's Kirker synthetic enamel, it DOES use a hardener.
Old 04-12-2007, 11:13 AM
No its made by Valspar I know the paint gets hardner,what I want to know is does the primer-sealer get hardner or just reducer?
The JD paint is made by sherwin williams if you can find a paint store that sells SW or Martin Senour they can hook you up.
Unfortuntly Ive sprayed several gallons of that JD paint restoring tractors and you will get about 4 months before that crap starts to die even with the hardner.
IMO its a waste of time and energy spraying that stuff.
Old 04-12-2007, 11:57 AM
Sorry to differ with you,but i've had e-mail conversations with Valspar about this product and they produce it for JD.And there seems to be a lot of people on this forum that has used it and loved it.Type in blitz black for a search and you will see what I mean.All I want to know if if I'm to put hardner in the primer-sealer or not.
Old 04-12-2007, 01:42 PM
yragat, My first reply was to the wrong post - I have used that enamel on equipment rebuilds but never on a car or truck. It does indeed need that hardener or as was pointed out it will not last long at all. With the harder however this stuff looks darn slick if applied properly and will hold up surprisingly well, I still would not consider it for a vehicle unless it is just a beater.
Old 04-12-2007, 03:51 PM
I would have to say... E-mail the manufacture. Apperently you already have their address. You probably would of already had your answer.
Old 04-12-2007, 04:27 PM
Do I use hardner in the primer-sealer also?
Old 04-13-2007, 12:30 PM
X711
What is the primer ??? do you have a part number.
Valspar makes a lot of products.
X711
Old 04-13-2007, 02:44 PM
X711
Its john deere buff primer sealer JD#TY25659 there is a # in top of the can (might be valspar#) 6372004345 Thats all I have
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
acrylic enamel vs synthetic enamel? yragat Body - Exterior 3 03-30-2007 08:48 PM
Synthetic Enamel & Acrylic gilby246 Body - Exterior 7 12-29-2005 08:54 PM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 06:19 PM
Catalyst substitute for Western synthetic enamel? myfamiliacc Body - Exterior 2 06-07-2005 06:40 PM
