None that I've ever heard of. I run only synthetics in all my vehicles and have never had a problem switching brands.
Centerline |
If I remember correctly, Castrol (Syntec) is a blend, not 100% synthetic. There are no problems with switching, assuming your engine is in good condition. I have never heard that you should mix some conventional oil with the synthetic. What is this supposed to accomplish?
Vince |
(I have never heard that you should mix some conventional oil with the synthetic. What is this supposed to accomplish?)
That was a mistake on my part, I meant to say you shouldn't mix them. Thanks for the input, I built this engine a few years back and it only has about 20k miles on it so I don't think the change in oil will greatly effect the performance of the engine, I was more concerned with the chemicals in the two oils being compatible. |
Hmmm, I heard long ago, can't remember if it was a reliable source, that mixing synthetic with fossil oil was reasonable from a money standpoint - that one to two quarts of synthetic gave the protection benefits without the expense of using 100% and was an acceptable procedure. I'll try to find the reference and repost if I can find the answer.
302/Z28 Castrol Syntec is actually fully synthetic. Croz your right the best synthetic motor oils can't be bought at the local parts store. Check out AMSOIL's website, they have extensive tests on the site, they beat every synthetic brand you can buy at a parts store, Castrol, Mobile 1, Pennzoil, ect ect. and I believe they also have a test showing how their oil out did Red Line or Royal Purple, I can't remember which.
Mike |
Mobil 1 was second in the test to Amsoil. The test I saw didn't even list Royal Purple. The fact is that Amsoil and Mobil 1 were so very close in performance it was meaningless. There was only about a ten or fifteen degree advantage Amsoil had on Mobil1 on the high temp test. That temp was far above what your seals and gaskets could withstand, so what is the point?
Vince |
302/Z28, I couldn't find the original article I mentioned as it was separate from the tests you saw. I did find these two AMSOIL related articles though. http://www.performancemotoroil.com/Royal_Purple_info and http://www.performancemotoroil.com/Dyno_test
Vince I do agree with you, all synthetic oils have an order in which one is better than the other, but the differences are so minimal and the points at which some fade is well beyond the points an engine could ever go, so to the engine it really doesn't matter which synthetic you use. But personally, since they all cost pretty much the same, except Red Line, if I'm going to dish the extra money out for synthetic I'm would buy the one that does the best in the tests. Mike |
I would use Amsoil, if it were available at Auto Zone, or Advance Auto. I do use Amsoil air filters in my cars however, after reading the test that nailed K&N. Having to order the oil is a main pain, Mobil ! is readily available, as are their filters.
Vince |
DONT USE PENZOIL!!!!!!!!!!!!IT SUCKS/castrol,valvoline,roal purple only oils i trust,personally i run valvoline VR1 racing synthetic oil.the hydraulic lifters love it,dont know why?and it lasts
