Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - synthetic transmission fluid upgrade
Old 06-27-2006, 10:16 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Most modern synthetic lubricants are totally compatible with conventional oil. Check the label on the can to confirm. At any rate, unless you drain the converter or flush it the majority of your fluid will be conventional. Over several fluid changes that ratio will swing toward the synthetic.
Vince
