Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - synthetic transmission fluid upgrade
Old 06-27-2006, 11:57 AM
russlaferrera russlaferrera is offline
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
trans fluid change
Find out how much trans fluid you need, plus 1 qt. When I change the trans filter I disconnect the upper trans cooler line from the radiator then I put a clear hose on the end, put it in a pail, fill the trans with fluid. Start the car in neural, add fluid as it is running about the amount that is coming into the pail. When the fluid changes color shut the engine off . Hook up the cooler line, check the trans fluid level.
