Most modern synthetic lubricants are totally compatible with conventional oil. Check the label on the can to confirm. At any rate, unless you drain the converter or flush it the majority of your fluid will be conventional. Over several fluid changes that ratio will swing toward the synthetic.
Vince |
trans fluid change
Find out how much trans fluid you need, plus 1 qt. When I change the trans filter I disconnect the upper trans cooler line from the radiator then I put a clear hose on the end, put it in a pail, fill the trans with fluid. Start the car in neural, add fluid as it is running about the amount that is coming into the pail. When the fluid changes color shut the engine off . Hook up the cooler line, check the trans fluid level.
| transmission fluid temperature | nixwillys | Transmission - Rearend | 1 | 04-16-2006 01:03 PM |
| 1994 Grand Am Transmission fluid question | StevenC | Transmission - Rearend | 0 | 07-18-2005 10:23 PM |
| Transmission Information. | M&M CUSTOM | Transmission - Rearend | 1 | 08-24-2004 03:15 PM |
| How Much Transmission Fluid? | EazyDuzIt102 | Transmission - Rearend | 8 | 01-12-2004 03:28 AM |
| Transmission fluid in motor oil? | Psydex | Transmission - Rearend | 2 | 08-13-2002 02:29 AM |
