T-10 ????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2005, 06:24 AM
Last journal entry: PICTURE TEST
T-10 ?????
Here is a new one....
A customer was talking to me about a corvette he is working on. It has the first generation T-10 in it. They use a aluminum bearing retainer. He says that after driving the car for a period of time, enough to get it hot. The trans will stop shifting. He looked under the gravel guard and said it looks like the throwout bearing is getting stuck on the bearing retainer. Like it's expanding from the heat and seizing the throw out bearing...
Anybody ever run across this problem?????
Keith
Old 06-01-2005, 07:16 AM
Wow, is it not shifting due to lack of clutch disengagment or tranny bind?
Old 06-01-2005, 07:17 AM
aka Duke of URL
FORD had the same problem with their T5. A steel retainer cures the problem.
Old 06-01-2005, 08:05 AM
Trans
56, I think it's due to the clutch not releasing correct because of the throwout bearing bind.....
kultulz. I'll have to check and see if they make a replacement out of steel.. Thanks
Keith
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
10 Ways to Look Like an Election Season Sucker Jon Hotrodders' Lounge 63 11-19-2004 06:34 AM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
40 ply/s 10 clip gcorbit Suspension - Brakes - Steering 0 01-28-2002 03:53 PM
