T-10 ford borg warner - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2012, 12:56 PM
Can anyone ID my T-10, side of case= E245 3 I came up with 1975 but not sure on that.
Old 08-29-2012, 10:11 AM
Thats a date code. you need more info. Look for something cast into the main case like T10H-1. Now, this will only tell you what was SUPPOSED to be in that case, which may or may not be whats in there now. If you want to know what ratios, you have to count teeth
The Following User Says Thank You to AutoGear For This Useful Post:
310at901 (08-29-2012)
Old 08-29-2012, 12:55 PM
Last journal entry: Paint
Ford used T10 transmissions in some of the early Mustangs. The date code might be for a 1965. Not sure on that. I had one that came in a 66 Mustang.
Old 08-29-2012, 03:02 PM
Other numbers on T-10- 148 B and W-1 920 310at901. Thanks
Old 08-30-2012, 03:25 PM
Have a borgwarner t 10 don't know wat it. **** input shaft 8 and half inches long bolt pattern cross top 6 an 16th cross bottom 6 an 5 16th top to bottom 6 an 7 8th thanks for any help
Old 08-30-2012, 06:57 PM
user151's Avatar
To paraphrase Dave Barry, that would be a good name for a car show band, "counting teeth."
Old 09-04-2012, 02:45 PM
Took all numbers off main case and tail shaft can't find anyone who knows what they mean thanks jack
Old 09-04-2012, 02:54 PM
It's better to post a picture of the T10. They used T10s in lots of different cars. It could be anything.
Old 09-04-2012, 05:13 PM
Will have my daughter send pics of 4 speed should she use your e mail thru hot rodder e mail that I have for you jack
Old 09-04-2012, 06:00 PM
Here are the pics of the transmission.
ID:	67727   Click image for larger version
Old 09-05-2012, 05:48 PM
Looks like a T10 from a AMC. The AMCs were the first Super T10.
Borg Warner Transmission and Ford 8.8 inch rear end mlarocque2@cogeco.ca Transmission - Rearend 1 03-29-2011 10:40 AM
Ford Borg Warner T10 Codes 65fbstang Transmission - Rearend 0 05-27-2007 11:07 AM
Borg Warner T-10 ID - Ford snakestang Transmission - Rearend 1 08-07-2006 10:40 PM
Borg Warner T-50 Super Chevy Transmission - Rearend 5 03-10-2006 09:05 PM
Borg Warner T-10 i.d. help L72Belair Transmission - Rearend 3 12-29-2005 11:03 AM
