T-10 specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2003, 04:23 PM
MI2600's Avatar
Member# 3287
T-10 specs
Tried the KB, but found everything but what I need.
Anybody know what the gears ratios were in the Chevy T-10s?
Old 12-22-2003, 04:54 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
That the exact reason I put up the information posts at the top of this forum.
You will find this link in the transmission post- Automatic Transmission Applications.
http://www.dandltransmission.com/
Then go to the second link down on the right column titled:
Borg Warner Parts List
T-10 / ST-10
Click that and it will take you to a link at the bottom left which will show you the following information.
Gear Ratio
1st, 2nd, 3rd, 4th
T-10 Close Ratio 57-62 2.20, 1.66, 1.31, 1.00
T-10 Close Ratio 62-65 2.20, 1.64, 1.31, 1.00
T-10 Wide Ratio 61-62 2.54, 1.92, 1.51, 1.00
T-10 Wide Ratio 62-65 2.54, 1.89, 1.51, 1.00
T-10 Close Ratio 64-65 2.20, 1.64, 1.31, 1.00
(HI Nickle)
ST-10 74-95 2.43, 1.61, 1.23, 1.00
ST-10 74-95 2.64, 1.75, 1.33, 1.00
ST-10 74-95 2.88, 1.91, 1.33, 1.00
ST-10 74-95 3.42, 2.28, 1.46, 1.00
