T-18 ratios - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2012, 09:28 PM
Wiki Edits: 31
T-18 ratios
I just bought an '88 T-18 out of an F-150 that had 90k miles to put in my hotrod. I know it's tall and rough shifting, but I'll make it work and it was only $175..
Just wondering if anyone knew what the 1st gear ratio is. I know most are 6.32:1 but that also some are 4:1. All the info I can find stops at 1986, but I know they are common in F-150's 1987-1988, but only fully replaced in 1992.. Both are too tall for a normal start, but I'm curious.. Havn't cleaned the trans off so I dont the numbers.
Old 01-20-2012, 11:06 AM
According to my boss George, all the late T-18s were 6.32:1 except for the Charles Machine industrial units.
Now...a little gimmick from back then:
If you had one of these new; and you had trouble with the 2-3rd ratio split being too big, Ford would give you the 4:1 or even the 5.11:1 1st gear gearset under warranty. Your best bet is to count the teeth; although I can't imagine why you shouldn't be able to chuck it in 1st and turn the input and count the mainshaft (output) and see if you get 4, 5 or 6:1
Old 01-20-2012, 04:26 PM
Wiki Edits: 31
That's what I'm going to have to do. I just put it in storage before doing that, so I'll have to wait until my next day off to count it.
Need some help sorting out tranny ratios and rear end ratios firstgear Transmission - Rearend 3 11-06-2008 07:39 AM
Rear end ratios denbar Transmission - Rearend 3 05-08-2005 09:40 AM
How do these gear ratios look? rlackey Transmission - Rearend 2 04-24-2005 08:33 PM
Gears and Ratios Fragzem Transmission - Rearend 7 02-05-2005 06:52 AM
rocker arm ratios molevolent_creations Engine 2 10-26-2003 05:09 PM
