T-200 metric to T-350 swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2011, 03:08 AM
JLBpontiac350's Avatar
85' grand prix,th200M,chev305
hello, i'm wondering what would have to be done to swap from a th200 metric tranny to a th350. the motor is a chevy 350. not sure if i would need a new x-fer case or new drive shaft. or if would be cheaper to just get the th200 metric rebuilt? any thoughts??? thanks guys
Old 04-23-2011, 03:58 AM
tnsmith10's Avatar
when will it rain???
the metric 200 and the th350 are the same length. everything will cross over but, the cable on the right side of the case, the metric 200 uses throttle pressure on that cable for shift timing and pressure, not just kick down, like the th350, the opening of the case for the cable on a metric 200 is bigger than the th350.
you mention transfer case, just what are you referring to? as the metric 200 is a 1 piece case, from bell housing to tail shaft.
Old 04-23-2011, 05:21 AM
im a bit of a laymen when it comes to transmissions sorry. lol but i think im gonna go with rebuilding the th200 metric. i found a "master rebuild kit" for like 85 bucks...my newer question is...is this a full rebuild kit or will i need other things...the kit includes overhaul kit, friction clutch plates & standard steel plates. my problem is that my 1-2 shift flares and slams into second and third gear will not engage....on another thread i was told to not dump money away and just rebuild it. so will i need anything no included in the kit?
thanks guys sorry to sound like a wanna be hotrodder...im learning as i go
Old 04-23-2011, 05:57 AM
so to be more specific about the "master kit" it total it includes:
paper gaskets, O rings, lip seals, metal clad seals and sealing rings, friction clutch plates & standard steel plates
just wanna make sure i don't need anything else to fix my problems....
Old 04-23-2011, 11:24 AM
kit
your gonna need a 2ng gear band and a full bushing kit i would look for a kit that includes them also get a shift kit
Old 04-23-2011, 03:45 PM
found the bushing kit but im not sure what i would need for the 2nd gear band?
site where im planing on buying the parts is
http://www.bulkpart.com/Merchant2/me..._Code=200-200C
please specify which is the 2nd gear band if they have it on there thanks bud
so far i know ill need part #'s
# 54006A (master kit)
# 54030A (bushing kit)
they have 3 differant band kits which would i need?
# B54022A Band 200 / 200-4R / 325 series flex
Various brands - New band
$14.06
# N54022A Band 200 / 200-4R
New band, value import also fits 325 / 3254L
$8.71
# N54022B Alto Band, 200 / 200-4R Power Band
New band Alto Red Eagle, Power Band Thich anchor / high performance lining 2 1/4 wide
$25.32
Old 04-25-2011, 06:54 PM
band
theres only one band in a 200 anyone will work that you listed but if your going for h.p. the last one is better
Old 04-28-2011, 09:05 AM
SSedan64's Avatar
The last Band listed is better but, it's 3/8" wider. You need a new Direct Clutch Drum to use the Wide Band, if not it will burn the outer edges of the Band. A standard width Alto Red or Carbon Band will work & be cheaper.
Some TH200C Info>> http://www.drwtransmission.com/thm_200C.htm
Old 04-28-2011, 09:17 AM
cool. nice to know some history. so for now im just gonna (when i get the gasket in) try new fluid and filter. when i removed the pan i found NO metal shaving, if they where there they where very very very small, but i did find a good amount of what seemed to be guck or some kinda thick slimey junk all over the pan, i cleaned the pan like new and found the magnet through the slim. not sure what this guck was but i cleaned as much as possible out. im droping the valve body to put in a shift "correction" kit that claims it will fix a few of my problems. im not worried if it dosnt fix it 100% because i didnt pay hardly anything for the correction kit, and it seems VERY simple to install. the whole kit consist of 5 springs 2 little dowls (one half the size of the other), one ring with a cut in it, looks kinda like a piston ring(i know its not just referancing what it looks like) and two little hallow washer lookin things which look like the dowls will fit into, and a set of drill bits, also comes with complete instructions...i think i can handel that lol....so it wont cost much to see if that dose the trick. cross your finger, and if anyone has used this kit, i never refuse tips heres a link to the kit lemme know if you know anything about it.
**** KIT
Old 04-28-2011, 09:18 AM
idk why it stared out the word sh1ft lol
Old 04-28-2011, 09:58 AM
SSedan64's Avatar
The Superior/Fairbanks brand Kits are good, TransGo brand also.
http://superiortransmission.com/
http://www.transgo.com/sk_generalmtrs.php
The Guuk in the Pan is probably clutch fiber material from worn Clutches/Band.
It's normal for there to be some material, a lot is usually a bad sign.
200-4R swap question? zbhover Transmission - Rearend 3 07-26-2009 06:00 PM
200 metric to a th400 BRSleeper2 Transmission - Rearend 10 07-14-2008 11:04 PM
200 metric/200r 2004r Eric64 Transmission - Rearend 1 06-07-2007 07:19 PM
200-4R swap for 350 79TA400 Transmission - Rearend 4 01-05-2006 10:45 AM
350 chevy metric ring's 406 ss monte Engine 3 05-31-2004 07:45 PM
