t-200c trans, im not familiar with some of parts listed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2011, 08:00 PM
JLBpontiac350's Avatar
85' grand prix,th200M,chev305
TH200c transmission i have a shift kit and im not familier with some of the parts that the directions referance.
1:TV valve
2:Throttle Valve
3:Inner roll pin
4:Shift TV valve
5:Coiled Pin
6:Shift TV plug
7:1-2 Shift Valve Spring
8:Accumulator Piston
9:Valve Body Plate (where is it located via the valve body)
10:Governor
11:Exhaust
12:Converter clutch apply valve
13: Turbine Shift
14: Pressure regulator Valve
15:TV cable settings: after TV cable has been installed, open the throttle to Wide open throttle position. the TV pluger should be flush with the TV bushing on the valve body, this will give you correct TV adjustment every time. ( i need that whole thing explained lol)
so any help yall could give, like where these parts are what they do and any tips would be great thanks
JLB
Old 04-29-2011, 12:32 PM
SSedan64's Avatar
Originally Posted by JLBpontiac350
1:TV valve
2:Throttle Valve
3:Inner roll pin
4:Shift TV valve
5:Coiled Pin
6:Shift TV plug
10:Governor
11:Exhaust
13: Turbine Shift
JLB
You really need an ATSG Manual to ID & locate these parts but, I'll try to help as much as I can. I can't find a Diagram of the Valvebody online. I did find a Diagram with other details, I'll post a link to it .
#1 thru #7 are located in the Valvebody.
#8 is part #927 in link/Pic.
#9 is part #947
#10 is part #680
#11 ?? possibly TV Exahust ball is in Valvebody.
#12 is in the Pump under TCC Solenoid, has wires going to it.
#13 ?? possiblt Turbine Shaft, Shaft that goes in to TC/TorqueConverter.
#14 is in the Pump.
#15 is on/at the Carb or Throttle Body.
Trans Diagram>> http://www.makcotransmissionparts.co...f/200-200C.pdf
Pump diagram>> http://www.sonnax.com/system/new-ann.../65912-01K.pdf and
Valvebody TV Pic>> http://www.sonnax.com/system/new-ann.../65754-02K.pdf
Did the Superior Kit come with any instructions? If not they may be able to send you something to help. I have a GM 200C Principles of Operation and Troubleshooting Manual but don't have a scanner for Pics etc..
Swap 200c for 200r4 DieselCutlass Transmission - Rearend 17 09-11-2008 01:14 PM
200c tranny swap biscuit63 Transmission - Rearend 0 04-06-2007 08:31 AM
TH-200C Kickdown? Silver_Camaro Transmission - Rearend 3 05-08-2005 08:35 PM
THM 200C Help vector006 Transmission - Rearend 7 07-07-2004 10:19 PM
200 or 200C Tranny Mrfixmaster Transmission - Rearend 1 12-17-2002 04:50 PM
