t-3 headlights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2009, 06:20 PM
bluebird
t-3 headlights
At a friends salvage yard I pulled all of the T-3 headlights. When I tried to test them they fill with smoke and blow out. I tested then with a 12 volt battery so can anyone explain why this is happening.Thanks
Old 08-18-2009, 10:27 AM
The only way they can burn out like that is with the presence of air. If the bulb isn't cracked anywhere, the air got in thru the connector spade seals, which were probably disturbed while removing the bulbs from the cars.
Old 08-18-2009, 09:36 PM
bluebird
t-3
Sounds good enough for me. Some were a little hard to get out. Thanks
car dies when I turn on headlights onebadmerc Electrical 15 06-24-2009 07:44 PM
Relays on headlights kleen56 Electrical 38 04-26-2009 05:24 PM
headlights quit working alabamasho Electrical 14 04-02-2009 08:19 PM
1939 Plymouth Headlights; Halogen Replacements and Missing Sockets hduff Electrical 5 02-12-2008 11:30 AM
French Headlights D M N Body - Exterior 17 07-15-2003 01:04 PM
