t-350 1st and reverse at same time - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2014, 09:16 PM
this is a sb 350 with a t350 traney, ever since the trany was rebuilt,with a shift kit - trany has all 3gears in drive -neutral and reverse and 2nd are fine also park. The problem is when manualy shifted into 1st the car wont move,feels like reverse clutch is also being engaged. a friend told me that he thought a check ball -or valve was improperly instaled?? Unfortunatly he passed away a couple of months ago, before he could fix this. Does some one know what he was refering to Thanks Larry.
Old 07-18-2014, 09:41 AM
S10xGN's Avatar
Gotta love a turbo!
There are some trans-brake kits that do this intentionally. Not sure how to tell if one of these was included in your "rebuild", but one of the resident gurus should be able to guide you through the ID process...
Russ
Old 07-18-2014, 11:57 AM
this had a shift kit instaled when it was rebuilt in about 1990 , but i dont remember any mention of a trans brake at the time it was rebuilt. but you could be right, this is a 49 chevy street rod, so a trans brake would't be much use, I'm guessing ,but anything is possible Thanks Larry
Old 07-18-2014, 12:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
your deceased pal may been correct. A check ball in wrong spot, vavle body gaskets swapped.
i've seen snap ring left out for the center support, cause a binding in reverse and manual low gear. Center support is pushed forward into gear train since the snap ring was not installed. Just a thought
Sewing machine comparison-long time seamstress, 1st time upholsterer - Singers altheapdx Interior 8 09-06-2012 12:27 AM
1st post, 1st time user Moondog1977 Introduce Yourself 2 11-04-2011 04:02 PM
Hello, long time luker 1st time user.. RickyDoors Introduce Yourself 1 08-20-2010 04:22 PM
Turbo 350, 1st and reverse gears only rodder1-2B Transmission - Rearend 2 06-20-2008 11:52 PM
long time reader, 1st time user brandon624 Introduce Yourself 1 03-13-2006 05:16 AM
