T-350 2-3 Accumulator
If your spacer plate has the 2-3 accumulator passage blocked, does it even matter if the 2-3 accumulator spring is installed or not? I would think that the spring also aids in cushioning the apply band servo, so keeping it installed would not matter. Any thoughts?
Either way, I removed the spring, added a spacer, then a washer, and replaced the e clip.
Cushion the servo apply for the braking band? I would think the spring under the T-350 servo piston. As I recall a T-400 coasting band spring will replace the softer OEM T-350 spring under the coasting band servo piston. TransGo kits come with stiffer servo spring for the T-350 trans, some TransGo kits have it , others do not Spacing the T-350 coasting band servo ''up'' out of the v-body slightly will help with shift timing slightly with band apply when manually shifting the T-350 trans
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| 88 700r4 accumulator | weedy64 | Transmission - Rearend | 2 | 05-09-2011 06:34 PM |
| Which way for the pinless accumulator piston A or B ? | old yukon | Transmission - Rearend | 5 | 05-05-2011 11:44 PM |
| 3-4 accumulator 4l60e | t00lmanii | Transmission - Rearend | 3 | 10-18-2009 04:31 PM |
| 4L60E Accumulator Sequence | SINGLE_SHOT | Transmission - Rearend | 2 | 09-17-2009 11:46 PM |
| Blocking 2-3 Accumulator | nova69 | Transmission - Rearend | 4 | 01-09-2009 11:27 PM |
