T-350 or a 4 speed Saginaw for my hotrod? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2013, 11:57 AM
I have a 4 speed sag 3.11 first gear or a th350 for my hotrod. My engine is approx. 330 hp 350. All opinions welcome.
Old 03-06-2013, 12:10 PM
35terraplane's Avatar
I would have to know what you are building.
Bob
Old 03-06-2013, 01:27 PM
big gear head's Avatar
High Performance Rear Ends
Manual transmission is always best in my opinion. All hot rods should have a clutch pedal.
Old 03-06-2013, 03:20 PM
Just building a car for fun just have always been told how the old sags dont hold up during spirited driving
Old 03-06-2013, 03:42 PM
LOL ....Real hot rods always have a clutch pedal. With that said. If you are looking forward to "spirited driving" it wouldn't hurt you to have a back up transmission waiting.........
Old 03-06-2013, 04:46 PM
Don't hold me to my word, but i thought the 3.11 sag were only put in the lower powered four and six bangers. I know we put them behind some low powered v-8 and they held up well. But you are going to have a motor of over 300 hp, be prepared and have a spare tranny. That 3.11 will get you out of the hole faster. I know of one that was put in a old school bus when it lost its tranny, and it was geared about the same as the origilnal tranny.
Old 03-06-2013, 05:59 PM
Going Deaf!!!
I have been down that road and would never again use a 350. Spend the money and upgrade to a 700r4 and you will be able to enjoy your ride both from a nois elevel and also at the pump!!!
Old 03-06-2013, 07:27 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Go go with the manual trans..... rowing through the gears increases the grin factor.
And the longevity of that classic Saginaw is directly proportional to hp and traction. Not much HP & or not much traction should result in long tranny life.
Old 03-06-2013, 11:21 PM
trans
Sell them both and buy a Muncie 4 speed. LOL! It would depend on how you want to drive it and where you are going to drive it. The 350 would probably hold up better, but nothing better then running through the gears. Tough call.
Old 03-07-2013, 10:23 AM
Our first question should of been, is it set up for a stilck or auto? Then the second question should be how much work are you willing to go threw to get it that way? If it's a stick and you want it that way, i'd opt for better tranny than the sag. If it's a auto, and you want it that way, i'd opt for a 200 4r and have your lower gears for fun and the overdrive for cruzzing. There are several reasons i like the 200 4r. If you ever change your mind down the road (and i have several times) you can change things back, because you won't have to get a new driveshaft again. I still have my 350 tranny and if my children want to put my nova back to original, it easy to do.
4 Speed Saginaw TwoFace69 Transmission - Rearend 3 11-10-2009 05:32 PM
saginaw 4-speed rockandroller1991 Transmission - Rearend 4 04-04-2009 09:43 PM
saginaw 4 speed i.d. TNT-59 Transmission - Rearend 1 01-10-2009 12:50 PM
saginaw 4 speed tomasmika Transmission - Rearend 3 09-03-2007 12:09 PM
saginaw 3-speed ? bowtieorbust Transmission - Rearend 2 01-12-2004 08:54 PM
