Why would you want a manual?
I can shift my TH400 anytime I want, Or leave it in drive, MY choice. I had it built locally by Jeff Wingfield and it shifts soft untill you get on it then it blows your socks off. It will shift up or down when I tell it to and the gov is set to do the right thing on the street. No reason for a full manual IMHO Keith |
RE: the t-350 trans... Is the detent cable hooked up from the trans to the carb? have you adjusted the vacuum modulator on the trans IF it is adjustable? Inside the nipple for the hose on the modulator is a small screw. Thread it in for later shifts. The t-350 trans not down shifting to first gear at a full stop , usually is a sticky governor. Gov is under the press on round cover near the rear of the trans. Removing the cover is easier than installing it back on. Check for clearance to re-install the cover before removing it. RE: t-400 Quote:
IF my guess here is correct..... then check for a bad modulator valve. Pull the vacuum hose off modulator, IF oil comes out , it is bad. Check for vacuum to the modulator , at the modulator. Check the wire hooked up on the drivers side just behind the shift linkage. This is for passing gear. IF there is 12 volts there with the ignition switch "on" , engine = "off " , the passing gear switch is defective or out of adjustment. check these items , post back when you can
At the Bonneville Salt Flats, first gear is known as 130 mph. |
