T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2014, 01:05 PM
T-350
I recently swapped the innards from a 350 six inch tail shaft into my 350 nine inch tail shaft. When I disassembled the six inch and installed it exactly how it was into my nine inch 350 I noticed that it didn't have the clutch accelerator spring on the side and it only had one check ball. Is this normal? When I first did the swap the tranny worked fine for a day then it hard shifted into second and after that now it only goes into first and reverse. Any suggestions???
Old 07-18-2014, 12:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Your terms confuse on part.
Clutch accelerator spring on the side?
One check ball used is common on some shift mods.
No shifting 1 - 2 -3 could be broken governor gear (plastic) , stuck governor, no vacuum to the modulator , stuck shift valves in the valve body.
Is the detent cable hooked up or removed?
Old 07-18-2014, 01:02 PM
Opposite side of the governor housing is a cap with a snap ring. There is a blue spring that my other 350 had. I'll check the governor and the other valves that you mentioned. Thank you for your response!
Old 07-19-2014, 09:02 AM
My mistake it's the accumulater spring that is missing and I do have the kick down cable connected.
350/350 set up in a questionable car.(1956 oldsmobile) Mike Hateful Hotrodding Basics 14 01-25-2015 07:51 AM
350 sbc with t-350 Trans, size of bolts to blockneeded? Canuckcamaro Transmission - Rearend 2 03-10-2011 07:46 PM
351 Windsor: minimum 350+/350+ with stock crank,rods and heads? BB72R-Yes Engine 5 07-20-2010 09:18 PM
Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? offroader9 Engine 1 04-07-2010 02:07 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
