T-350 auto transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2011, 09:29 PM
StudebakerDean
my transmission is th elonger shaft and I want to confirm a hole in it. drivers side towards the rear, theres an oblong hole w/ a small screw hole in side the oblong. im thinking speedo connection? i can put like 3 fingers in the hole. wondered too if I can fill the trans w/o this hole having whatever goes in it in place. didnt want to lose all the fluid.
Old 10-08-2011, 09:49 PM
SSedan64's Avatar
Yes, that's where the Speedo Bullet/Housing & Gear goes. It will dump fluid from there if the parts are missing.
http://www.makcotransmissionparts.co...f/350-350C.pdf
http://www.transmissioncenter.net/sp...n_______va.htm
TH350 parts > http://www.transmissioncenter.net/sp...____va.htm#350
Old 10-09-2011, 03:24 PM
StudebakerDean
thanks
ssedan64, thanks for the response. looks like I need 848,774,078,369,842 and 785. i might have 774and 848 inside. since it doesnt appear i can just ask for a th350 speedo cable, what parts would I ask for and where can I find them. i appreciate the exploded view w/ numbered parts.
Old 10-10-2011, 09:29 AM
SSedan64's Avatar
Did you look at the other 2 links above?
1st link shows Parts arrangement, Pic.
2nd link shows Parts.
Speedo cables are available there also. Cables are vehicle/length specific.
Auto transmission malfunction Aigbedo Moses Transmission - Rearend 5 04-30-2013 12:56 AM
Auto Transmission Leak Rat Ron Transmission - Rearend 8 05-25-2012 04:20 PM
Your favorite auto transmission? Studebaker Hotrodders' Lounge 30 04-23-2011 08:38 AM
what transmission goes on a 302 auto??/ acself03 Transmission - Rearend 3 04-09-2006 11:46 PM
Manual or Auto transmission? '54-Hunter Hotrodders' Lounge 20 01-12-2003 08:07 AM
