Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 cables questions
Old 11-10-2012, 10:47 PM
clayfromthebay clayfromthebay is offline
So here is what I am working with: 1970 Chevy C-10 Pickup, 383 engine with 4160 holley carb. I have the engine almost complete, just having trouble hooking up the TH350 transmission.
I am here on this forum to look for help and get my truck running correctly instead of starting it and accidentally having it run through my wall. It is fair to assume I dont have any of the cables or brackets and need to purchase everything new.
So far the transmission is in and connected to the engine with a torque converter spun on correctly. I've only put the transmission dipstick in and connected the cooler lines. I connected a line off the side of the transmission which I think is the speedometer.
I'm new to working on transmissions so I'm not totally sure what I need to do next. Theres the shift linkage, detent/TV cable, kickdown cable, vaccuum modulator? I'm just not sure which cables go where, what brackets I need, and there is a B&M shifter that is mounted in the truck but I'm not too sure what to attach to it. How much stuff do I need to hook up this transmission? Any help or direction would be greatly appreciated.
