Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 cables questions
Old 11-11-2012, 04:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To adjust the detent cable, you unlock the cable by lifting up on the lock located near the carb end of the cable, then w/the cable unlocked you open the throttle wide open, then snap the lock back down to hold the adjustment you just made by opening the throttle wide open. There are videos and text on this online if you need more.
