Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t-350 check balls location ?
Old 02-20-2011, 12:50 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by bodie filyaw
I put all the check balls in right,but noticed the servo.i put mine in smooth side up ,the diagram has it with the pocket side up. will this make a difference do i need to go back in and change it?
Pocket side on the servo piston must face the valve body piston
