t-350 check balls location ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2011, 04:45 PM
bodie filyaw's Avatar
GMC TRUCKS
need a diagram of check ball locations in a th350
Old 02-18-2011, 05:07 PM
SSedan64's Avatar
http://th350.netfirms.com/pages/7a2-61.jpg
Old 02-20-2011, 07:44 AM
GMC TRUCKS
Oopssssssss ?
I put all the check balls in right,but noticed the servo.i put mine in smooth side up ,the diagram has it with the pocket side up. will this make a difference do i need to go back in and change it?
Old 02-20-2011, 12:50 PM
Crosley's Avatar
Wiki Edits: 1659
Pocket side on the servo piston must face the valve body piston
Old 02-20-2011, 04:25 PM
GMC TRUCKS
thanks, appreciate the info
TH350 tranny check balls bodie filyaw Transmission - Rearend 13 02-02-2011 07:52 PM
Check balls in 1988 Iroc with a 1982-83 model 700r4 Mustangman2011 Transmission - Rearend 3 01-29-2011 09:04 AM
T-400 check balls jlwagner17 Transmission - Rearend 14 06-14-2010 10:54 PM
700r4 check balls sbc400_700r4_3.42 Transmission - Rearend 6 12-11-2008 01:48 PM
Turbo 475 check balls Greg T Transmission - Rearend 8 07-11-2007 09:40 PM
