T-350 cooler lines.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 07:50 PM
Which line is the outgoing line to the tranny cooler on a TH350, the upper or lower port??
Old 06-16-2008, 07:58 PM
TH350,
Upper ... Return/in
Lower ... Cooler feed/out
Old 06-16-2008, 08:11 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I went to the school of hard knocks ... where the tuition is high but the retention is exceptional !
I started going to that school 36 years ago. I might get my diploma next year! LOL
Old 06-17-2008, 11:33 AM
scapegoat's Avatar
Does it matter? I have an aftermarket cooler and I just hooked it up
Old 06-17-2008, 11:54 AM
It would if you still use the radiator cooler in line with it, I plumb them inline after it goes through radiator cooler.
Old 06-17-2008, 01:00 PM
Bookmark this link
http://www.tciauto.com/Products/Tech...r_fittings.asp
Cooler Fittings
General Motors Ford Chrysler
GM Transmission Cooler Fittings
Powerglide - OEM
Fitting Location Thread Size Flow Direction
Upper ⅛" Pipe Return/in
Lower ⅛" Pipe Cooler feed/out
Powerglide - Dedenbear
Upper " Pipe Return/in
Lower " Pipe Cooler feed/out
TH200C Metric, 2004R
Upper " Pipe Cooler feed/out
Lower " Pipe Return/in
TH350, TH250
TH400
700R4/4L60/4L60E/4L65E
4L80E (1991-1996)
4L80E/4L85E (1997 & later)
Rear " Pipe Return/in
Front " Pipe Cooler feed/out
Ford Transmission Cooler Fittings
C3, C4, C5, C6
Fitting Location Thread Size Thread Size Flow Direction
AOD
AODE/4R70W
E4OD/4R100
Chrysler Transmission Cooler Fittings
All Torqueflite
Front ⅛" Pipe Cooler feed/out
Rear ⅛" Pipe Return/in
Old 06-17-2008, 01:19 PM
Does it matter if I ONLY have it going to an aftermarket cooler mounted infront of the radiator?? right now the lower cooler lines is going to the bottom of the cooler and the top line going to the top of cooler. The fluid would be getting pumped up through the cooler. Does this matter or will it work??
Old 06-17-2008, 01:29 PM
In a stand alone situation like yours ... it should not matter ... the fluid is going thru the cooler. As a matter of fact ... as long as you just are using one cooler ( in the radiator or stand alone ) ... it should not really make much difference.
Hayden automatic transmission coolers suggests doing it this way ... when adding a additional cooler.
Old 06-18-2008, 12:50 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
My 2 cents...
I use a rather large plate and fin type cooler (as opposed to a tube and fin) and that is the only cooler I run. For better or worse. It sees no zero degree weather.
Now, I've some trans pro's explain it to me in such an analogy; after you heat a piece of metal nearly red hot, do you throw it in front of a fan to cool, or do you dunk it in some water to cool it quickly?
The difference in air to fluid cooling and water to fluid cooling.
I've used an infrared temp gun and shot the stand alone cooler after a brief 3000 rpm stall. The temp spiked to some 290* on the *in* !
Here lately I've been thinking of using BOTH coolers as pictured above in Deuce's post to 'normalize' the temps some. Who knows what the temp may be at the end of a full drag run with a burnout, dry-hop, pre-stage, stage, big stall as the lights fall and then finally the run.
350 trans cooler lines bill plise Transmission - Rearend 1 08-17-2011 12:37 AM
T-350 cooler lines, in & out? s10mk Transmission - Rearend 2 05-23-2010 01:32 PM
cooler lines ragincajun19 Transmission - Rearend 10 05-01-2007 03:01 PM
C6 cooler lines, which is in and which is out? MM in NM Transmission - Rearend 2 01-26-2006 10:18 PM
Th-350 cooler lines..where do they go V8 S-10 Transmission - Rearend 3 09-17-2003 08:39 AM
