T-350 Cooling Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 08:52 AM
T-350 Cooling Lines
This may be a dumb question, but does anyone know which line is the inlet and which is the outlet cooling line on a TH350? I'm installing a cooler and forgot which is which.
Old 07-22-2012, 09:14 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
I'm pretty sure that the front line on virtually every trans is the pressure side as it is closest to the pump.
Edit:
Here are some somewhat "generic" installation instructions
The diagram seems to confirm my theory, but as described a bit later ... the "drain pan" method will tell you for sure.
Old 07-23-2012, 08:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
From here:
• Top line of the transmission = in from the cooler
• Bottom line of the transmission = out to the cooler
Note: All except TH200C and TH2004R- which are opposite.
The Following User Says Thank You to cobalt327 For This Useful Post:
tenfords (11-24-2012)
4L60E cooling lines? solidaxel Transmission - Rearend 4 05-12-2010 08:39 PM
Trans Cooling Lines MI2600 Transmission - Rearend 6 08-12-2006 05:32 PM
TH-350 Cooling Lines Flaring leejoy Transmission - Rearend 2 01-02-2006 08:53 PM
cooling lines Slant3 Transmission - Rearend 19 06-15-2004 02:21 PM
How flexible do cooling lines need to be? McDeuce Transmission - Rearend 3 03-22-2004 12:36 PM
