-   -   T-350: do i need a stall converter or use stock converter (http://www.hotrodders.com/forum/t-350-do-i-need-stall-converter-use-stock-converter-226817.html)
tbrown8338 12-04-2012 06:29 PM
i have a th350 tranny with a chevy 350 engine (468/268 cam with headers) and 411 gears in the rear. do i need a stall converter or will the stock converter work. the cam is very mild. i am not sure what i have now my tranny quit but i can't tell what torque converter i have. please help
thanks
tyrone
vinniekq2 12-04-2012 10:25 PM
even stock converters come in different stalls.If you are replacing the trans then also replace the converter.they are not expensive,just go to a local shop that rebuilds stock converters and ask for a stock(heavy duty) converter from a small engine.16-1800 is good enough for a mild engine
lg1969 12-05-2012 04:32 PM
I used to run a B&M Holeshot converter on my TH350 and ran really good. It works very nice on a mild 350. Hope this helps
