T-350 fluid capacity - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 06-25-2003, 08:28 PM
big455's Avatar
I just bought a new TCI street fighter turbo 350 tranny. I have filled the stall converter with fluid but not the trans. How many quarts of fluid does it take to fill it up? someone told me ten quarts but that seems like alot. thanks for any help!
Quick reply to this message
Old 06-26-2003, 03:46 AM
TH350 with converter holds 10 qts.
Old 06-26-2003, 04:01 AM
I did like this:
add to converter about 2 qts, to the tranny about 7 qts. Then I start the engine and add the rest checking level. after 24h need to add 0.5 more.
Old 06-26-2003, 06:55 PM
adtkart@aol.com
Unless the convertor is smaller than the original, it should hold 10 qts. Fill it up, checking it closely, with engine running while adding. You may get some inacurate readings on the stick after adding because of the fluid in the tube. Make sure the temperature is up to normal, and you have run it through the gears, when the level shows full. There is no reason that you should have to add any after 24 hours if it is filled properly the first time, unless you have a leak.
Old 06-26-2003, 08:55 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Yeah,Raise the rear,put in drive, add fluid untill full.
Thats all folks.
Old 06-27-2003, 10:02 AM
big455's Avatar
Thanks alot guys, I appreciate your help
Closed Thread
T-350 Fluid capacity cullencombs Transmission - Rearend 3 08-11-2012 12:34 AM
fluid capacity helrazr3 Transmission - Rearend 5 11-30-2010 09:59 AM
fluid capacity??????? 4dr77impala Transmission - Rearend 2 07-10-2007 08:34 PM
M21 fluid capacity mrl Transmission - Rearend 3 01-10-2007 01:02 PM
fluid capacity for 350 turbo mtmniles Transmission - Rearend 2 04-04-2003 05:01 PM
