-   -   T-350 Fluid capacity (http://www.hotrodders.com/forum/t-350-fluid-capacity-222742.html)
cullencombs 08-10-2012 04:25 AM
I just dropped the pan to install a new gasket. After replacing the pan i put one quart in it and it is showing full on the dipstick. Im guessing I have the wrong dipstick? Should I just throw 4 quarts in it and be done? This has the stock pan on it. Thanks!
the california kid 08-10-2012 04:41 PM
cullen
you ought to get to the bottom of the dipstick problem.
i guess you mean Chevy turbo hydromatic 350?
i'd fix the dipstick situation first.
have a nice day!
RWENUTS 08-10-2012 04:59 PM
How much did you drain out?
Put the same back in.
cobalt327 08-11-2012 12:34 AM
Start the engine.
Move the shifter through all the ranges (R, N, D, 2nd. L, etc.), then back to Park.
Remove dipstick, wipe clean.
Reinstall it then immediately remove and w/wet end held downward, read the level on the stick.
The fluid will rise slightly when fully hot if you are reading it cold.
