T-350 Fluid capacity - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2012, 05:25 AM
I just dropped the pan to install a new gasket. After replacing the pan i put one quart in it and it is showing full on the dipstick. Im guessing I have the wrong dipstick? Should I just throw 4 quarts in it and be done? This has the stock pan on it. Thanks!
Old 08-10-2012, 05:41 PM
cullen
you ought to get to the bottom of the dipstick problem.
i guess you mean Chevy turbo hydromatic 350?
i'd fix the dipstick situation first.
have a nice day!
Old 08-10-2012, 05:59 PM
RWENUTS's Avatar
How much did you drain out?
Put the same back in.
Old 08-11-2012, 01:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Start the engine.
Move the shifter through all the ranges (R, N, D, 2nd. L, etc.), then back to Park.
Remove dipstick, wipe clean.
Reinstall it then immediately remove and w/wet end held downward, read the level on the stick.
The fluid will rise slightly when fully hot if you are reading it cold.
fluid capacity helrazr3 Transmission - Rearend 5 11-30-2010 10:59 AM
fluid capacity??????? 4dr77impala Transmission - Rearend 2 07-10-2007 09:34 PM
TH400 fluid capacity?? ascen1 Transmission - Rearend 2 09-15-2004 10:09 AM
T-350 fluid capacity big455 Transmission - Rearend 5 06-27-2003 11:02 AM
fluid capacity for 350 turbo mtmniles Transmission - Rearend 2 04-04-2003 06:01 PM
