Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 Forward/Direct Clutch Piston Seals
Old 03-29-2013, 07:31 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
you will hear some hissing with air check.
If the clutch pack piston applies with low psi air pressure (30) you are fine.
Air gets by things easier than oil does
