Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 Forward/Direct Clutch Piston Seals
Old 03-29-2013, 06:44 PM
zardiw zardiw is offline
Originally Posted by Crosley View Post
you will hear some hissing with air check.
If the clutch pack piston applies with low psi air pressure (30) you are fine.
Air gets by things easier than oil does
OK....Thanks Crosley!.......Yeah.....they both move...the Forward one hisses less and airs up better.....holds.
The Direct one moves/airs up......then settles back down...using 30PSI, but when I first hit it with the air there's more pressure (using a pressure regulator that leaks a little) 30 it won't stay aired up.......but it moves, so thanks!..
