Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 Forward/Direct Clutch Piston Seals
Old 03-29-2013, 07:21 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by zardiw View Post
OK....Thanks Crosley!.......Yeah.....they both move...the Forward one hisses less and airs up better.....holds.
The Direct one moves/airs up......then settles back down...using 30PSI, but when I first hit it with the air there's more pressure (using a pressure regulator that leaks a little)......at 30 it won't stay aired up.......but it moves, so thanks!..
z
the bore area the sealing rings run in , need to be smooth, no ridges , grooves , burrs. Often the direct drum has a groove or 3 in it.
