T-350 Forward/Direct Clutch Piston Seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2013, 05:06 PM
Are these really touchy or something.......I lubed them well and put them in the bore......tried that wire deal to guide them in but that really didn't do much.....they actually pushed in halfway easily.......but when I air test them there's a hissing.......
Took the direct clutch apart and looked at the seals.......they looked pretty good....but there's still hissing......
Kind of stuck here.....don't know why or where it's leaking.
Double checked to see the lips point the right direction...
Also, the hissing changes when I rotate them.....
Again...are these seals really fragile or something to where it's really easy to screw them up?
Anybody got any other ideas of where it's leaking?
All the rings on the pump shaft are now new......and they seem to be OK too......
z
Old 03-29-2013, 06:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you will hear some hissing with air check.
If the clutch pack piston applies with low psi air pressure (30) you are fine.
Air gets by things easier than oil does
Old 03-29-2013, 06:44 PM
OK....Thanks Crosley!.......Yeah.....they both move...the Forward one hisses less and airs up better.....holds.
The Direct one moves/airs up......then settles back down...using 30PSI, but when I first hit it with the air there's more pressure (using a pressure regulator that leaks a little)......at 30 it won't stay aired up.......but it moves, so thanks!..
z
Old 03-29-2013, 07:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
z
the bore area the sealing rings run in , need to be smooth, no ridges , grooves , burrs. Often the direct drum has a groove or 3 in it.
T-400 direct clutch problem SaM91 Transmission - Rearend 6 04-16-2013 12:33 AM
4l80E Direct and Forward drum piston interchange blade42003 Transmission - Rearend 4 01-05-2011 09:25 PM
I'm sharing a t-400 trick to install those pesky clutch piston seals Big Buick Transmission - Rearend 4 07-19-2010 07:48 AM
Torrington Bearing between Direct and forward drum? 6426yy Transmission - Rearend 2 05-05-2008 02:28 PM
TH 350 Direct Piston Chezelle Transmission - Rearend 1 11-21-2003 01:05 PM
