T-350 front leak ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2011, 10:26 PM
rlb3's Avatar
T-350 front leak ?
I bougt a th350c and I put a new front seal in it, after I installed the trans it didn't leak at all but after driving a couple times the trans started leaking in the front, it just seems like its getting worse and worse, where could it be leaking from? The fluid is leaking exactly in the middle of the front of the trans, I wouldn't think it was the seal but I'm not sure. Any ideas?
Old 09-30-2011, 07:11 AM
delawarebill's Avatar
tranny leak
i'm no tranny exp by no means... but i still be look'n at the front seal.. maybe the input shaft bearing/bushing is going bad and do'n a wobble on the seal.. napa has them too...
Old 09-30-2011, 03:07 PM
rlb3's Avatar
Originally Posted by 10scnd70
There are numerous places a TH350 could leak. Even if you replaced the seal, there's a chance the pump bushing could have walked forward, which will cause a leak. Did you put silicone around the pump seal when you installed it? The pump has an o-ring that seals it to the case that have been known to leak. And...Don't overlook the converter hub. I've seen many of these crack at the welds. Most of the time, where the hub is welded on. The other possiblity are the pump bolts. Does it leak more while running or with the engine off?
Frank
It leaks more with the engine off. , i put the seal in dry
Old 09-30-2011, 07:00 PM
rlb3's Avatar
I finally crawled under the truck and majorly cleaned the trans, I found that the leak is actually from the tourqe converter lock up plug that is on the driver side, is there a o ring or sumthing like that to seal, or how do I fix this?
Old 09-30-2011, 07:59 PM
rlb3's Avatar
Yes, the lock-up plug has an o-ring. You'll have to drop the pan to collapse the retaining fingers that hold the plug in the case.
Frank
Ok that's great can I just use any kind of o-ring to seal it?, also should I put some sealant or something on the o-ring before installing it
Old 09-30-2011, 08:27 PM
rlb3's Avatar
Chevrolet 350 speedo o-ring is the same size. I use Permatex Ultra Copper on anything transmission related. It doesn't break down when introduced to transmission fluid.
Frank
Thanks for the help, I will go to the auto store tomorrow after work and get a oring and the copper stuff and a pan gasket
Noob - Front cam cover oil leak on SBC 350 seattlematt Engine 23 07-10-2010 12:14 PM
Front pump leak on 700R4 KeithB123 Transmission - Rearend 3 01-26-2005 07:40 PM
turbo 350 leak, front seal area 72chevelle Transmission - Rearend 5 06-03-2004 06:32 PM
350 front seal oil leak buddy Engine 4 08-29-2002 05:25 AM
