T-350 Front Pump Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2011, 11:11 AM
Hi All,
This is my first time posting here, because I have a question on installing a TH350 front pump. I did a search but didn't find what I was looking for.
I picked up this trans that had already been disassembled. I have it all reassembled but don't know if there is a certain position the front pump needs to be in. It wasn't marked before taken out. Do the holes only line up in a certain position? Or does it matter?
Thanks in advance.
Old 10-01-2011, 05:21 AM
S10xGN's Avatar
Gotta love a turbo!
Pretty sure it's keyed to fit only one way...
Russ
Old 10-01-2011, 06:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The pump can go in only one way for the bolt holes to all align correctly. Below are some links showing the pump, how to inspect it, how it's aligned/centered and how to use dowels made from bolts w/their heads cut off to help install the pump.
The pump has both a gasket under it and an O-ring around the outside of it to seal it to the case- both need to be in place.
http://www.hotrodders.com/forum/th35...ch-145361.html
http://koti.mbnet.fi/~narker/camino/tranny2.htm
http://www.carcraft.com/projectbuild...dup/index.html
Old 10-01-2011, 04:17 PM
Thanks guys, once I looked at it closer I saw how a couple holes are offset to align it only one way but still appreciate the responses.
T-350 Front Pump Seal 91CamaroDude Transmission - Rearend 3 10-04-2012 11:31 AM
TH-350 front seal on pump dakotaking81 Transmission - Rearend 1 10-26-2011 07:04 PM
350 Turbo Front Pump pandoura Transmission - Rearend 2 07-06-2009 08:34 AM
Turbo 350 front pump scapegoat Transmission - Rearend 9 02-22-2007 09:09 PM
TH-350 front pump seal nova72000 Transmission - Rearend 9 09-23-2006 03:17 PM
