are you going to take the pump out?
either way i take a 1/2 inch straight blade screwdriver and hit the edge of the seat towards the stator shaft . You prob will have to hit about 1/4 of it in then it should loosen up
Loctite the seal in and grease the inner part
make sure the snout on the convertor is not wore or scratched
good luck
