T-350 Front Pump Seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2012, 06:46 PM
Alright, I got the tranny out, and now am trying to replace the front pump seal, but it looks like the original one has been in there for decades, or someone globbed some sealant behind there... Needless to say its a PITA to get out & is starting to look somewhat finaggled. Without using a specific tool for pulling this off, would heat or anything help to pry it loose? Im using a jimmy and a long flat head and its not working all that well. Any help is appreciated.
Old 09-28-2012, 07:19 PM
are you going to take the pump out?
either way i take a 1/2 inch straight blade screwdriver and hit the edge of the seat towards the stator shaft . You prob will have to hit about 1/4 of it in then it should loosen up
Loctite the seal in and grease the inner part
make sure the snout on the convertor is not wore or scratched
good luck
Old 09-29-2012, 11:56 AM
pricesgarages's Avatar
look at the bushing and converter hub also if u remove the pum theres a o ring and permatex the pump bolts
Old 10-04-2012, 11:31 AM
It eventually came loose with no real issues, I wish I would have taken a picture of the tool my buddy used to put it back in. Essentially it is a metal cylinder sleeve that goes over the input shaft, and a few taps with a hammer on the back in and it sealed perfectly. Thanks your help!
TH-350 front seal on pump dakotaking81 Transmission - Rearend 1 10-26-2011 07:04 PM
TH 350 trans front seal ? 39chevy Transmission - Rearend 1 08-30-2009 09:13 PM
TH-350 front pump seal nova72000 Transmission - Rearend 9 09-23-2006 03:17 PM
th400 front pump seal question meev182 Transmission - Rearend 6 07-01-2006 08:22 AM
Front pump seal 700r4 KeithB123 Transmission - Rearend 4 09-29-2003 07:19 PM
