T-350 has me stumped (Is this a T-350 or T-350c?) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-02-2011, 10:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Odd that the solenoid wiring would be reattached and everything left as though the TCC was working. The reason for my curiosity is because I have a TH350C in my '80 Malibu wagon. Original tranny never been out of the car, has only had filter and fluid changes.
Because it has well north of 250K miles on it, I figure it is bound to need a rebuild eventually and the idea of switching it to a non lockup has been considered so the TC availability would be better, but generally speaking I like the lock up. Anyway, thanks for the input.
  #17 (permalink)
Old 06-02-2011, 02:06 PM
FastOrange's Avatar
Originally Posted by tnsmith10
the plate below the kick down assembly is supposed to have a 1/8th" hole drilled through it and i dont see it. also, i usually snip the wires off of the lock up solenoid to show that the trans has been converted, which also isnt the case with this trans. id pull off the lock up valve body and make sure that the lock up valve has been blocked off.
So you have a picture of the hole? i dont want to drill in the wrong spot
I Got this trans off a friend, he said it worked perfect, he said the shifts were normal like any stock trans, no neck snapper for sure.
  #18 (permalink)
Old 06-02-2011, 03:27 PM
SSedan64's Avatar
It also has the Unibell Case/Housing, fits Chevy & BOPC. These are getting very hard to find now.
I can't remember for sure but, I think a passage/port behind the Pump is blocked which cancels the need for the Valvebody Mod. TCC feed possibly.
  #19 (permalink)
Old 06-02-2011, 03:59 PM
FastOrange's Avatar
One of the reason i picked it up
  #20 (permalink)
Old 06-02-2011, 09:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there was a hole to be drilled in the stator support so the oil behind the converter hub seal would drain out... otherwise the seal could blow out from pressure build up
th-350 and th-350c 85-monte Transmission - Rearend 3 10-27-2008 08:42 PM
T-350 and T-350C What's the difference? 83elky Transmission - Rearend 17 03-10-2008 01:23 AM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 10:03 AM
Is it a T-350 or a T-350C? 82c10 Transmission - Rearend 4 07-05-2005 07:29 PM
Difference between TH-350 and TH-350C WakBordr7387 Transmission - Rearend 2 03-04-2005 10:22 PM
