T-350 has me stumped (Is this a T-350 or T-350c?) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 09:17 PM
FastOrange's Avatar
I picked up this trans the other day, it was behind a Chevy pickup with a 350 Olds Diesel infront of it.
I assumed it was a th350c because of this plug and the MV4 on the side.
*Plug looks like two prong plug, but it only has one wire, i checked when pan was off, other spot is just blank*
But when i pulled the convertor i found this
Also, My 3500 Stall from our th400 fits right on.
So if this is a regular old th350, what the heck is the plug for?
ANY help would be awesome!
Old 05-31-2011, 09:28 PM
cudablack2004's Avatar
i believe u have a th350c i just bought a trans out a monte carlo with 6" shaft no plug and says gm35 on the pump!
Old 05-31-2011, 10:05 PM
tnsmith10's Avatar
when will it rain???
its a converted to non- lockup 350. done that to a lot when people who had poor running engines and would rather pay for the conversion on a trans rebuild than to fix the engine right. what would happen is a vibration would come in when the converter clutch engaged and people would think its the trans. they would come in and say "i have a vibration on the last shift".
Old 05-31-2011, 10:16 PM
damn i wouldnt even had noticed that!
Old 05-31-2011, 10:33 PM
FastOrange's Avatar
This all makes sense now, because the tranny looks like it had been rebuilt at one time, the convertor it came with looked new.
So is this a good or bad thing?
Old 05-31-2011, 10:38 PM
tnsmith10's Avatar
unless you pull the pan and can positively identify that they did the change over correctly, you really wont know till you try it. have you dropped the pan and checked for debris?
the paint may be nice, and may have shown care, but in the end, a pan drop is a easy quick way to tell if it seems to be in decent shape, or its loaded with metal and probably not worth the effort.
Old 05-31-2011, 10:56 PM
FastOrange's Avatar
i painted it up, it looked like this when i got it.
I pulled the pan, fluid was nice and red, no burnt smell, everything looked super clean, Filter looked awesome as well.
FastOrange's Avatar
How do i tell if it was done proper?
Old 05-31-2011, 11:04 PM
FastOrange's Avatar
And also, if i want to order a shiftkit, do i get one for a th350c or th350?
Old 06-01-2011, 03:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The tranny, including the valve body, etc. will still be the "C". The changes to make the C able to use a non lockup converter are to the pump and input shaft/drum and a couple other small mods, so my guess would be to use the one for the TH350C- but I would almost expect that the tranny would have been kitted when the other mods were made.
If it were me I would try it as-is first to avoid any possible conflict w/shift kit-type mods that may have already been done to it and the addition of more/different mods to the valves and separator plate/gaskets, etc. Hopefully tnsmith10 will have a definitive answer for you.
Old 06-01-2011, 07:47 PM
tnsmith10's Avatar
other than the lock up valve blocked off, theres a small plate thats bolted down next to the lock up valve body. it should have an 1/8th" hole drilled roughly in the center of it. other than that, it looks like the input drum and stator have been swapped out like their supposed to be, so other than that it should work fine.
as far as the shift kit goes, like cobalt said, you want a "c" kit, because of the case. other than that, ive never kitted a converted 350, i just did some minor internal things to firm up shifts. like pull the 2-3 accumulator spring out of the valve body, and then also take a 5/16 stud a little over an inch long, and put in a pressure port, just above the 1-2 accumulator, and it blocks off fluid to the 1-2 accumulator for a firmer 1-2 shift.
theres more stuff out there, you may also want to check the sticky thread jakeshoe has about building a 350, lot of useful info there.
Old 06-01-2011, 09:18 PM
FastOrange's Avatar
Here is the valve body, Thoughts?
And thanks for the help guys!
Old 06-02-2011, 07:52 AM
tnsmith10's Avatar
the plate below the kick down assembly is supposed to have a 1/8th" hole drilled through it and i dont see it. also, i usually snip the wires off of the lock up solenoid to show that the trans has been converted, which also isnt the case with this trans. id pull off the lock up valve body and make sure that the lock up valve has been blocked off.
Old 06-02-2011, 08:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
tnsmith10, what would be the result if someone were to have just swapped out the hard parts, but didn't block off the lock up or drill the hole you mentioned, etc.? Could the trans actually function, you think?
Old 06-02-2011, 08:14 AM
tnsmith10's Avatar
well, in all honesty i dont have an answer for that. i learned to do the changeover when i was young and never saw anyone do it differently or tell me what could happen if these things i mentioned werent done. if i remember correctly, the hole was drilled for drain/pressure relief, id imagine from the t.c.c. oil that has no place to go. mind you, i learned how to do this at a young age, without being given full info on why. i just knew it worked, and didnt have any problems with the conversions i did. even had a 79 phoenix that i had a lock up case for but it never came with t.c.c., so i built as a conversion. the wife and her daughter drove it for 4+ years, and never had a single problem with it.
pretty sad that i know more inside of other transmissions better, along with how they work better than the 1st trans i learned how to build...
th-350 and th-350c 85-monte Transmission - Rearend 3 10-27-2008 08:42 PM
T-350 and T-350C What's the difference? 83elky Transmission - Rearend 17 03-10-2008 01:23 AM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 10:03 AM
Is it a T-350 or a T-350C? 82c10 Transmission - Rearend 4 07-05-2005 07:29 PM
Difference between TH-350 and TH-350C WakBordr7387 Transmission - Rearend 2 03-04-2005 10:22 PM
