T-350 Input Ring Gear Resistance to Turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2013, 08:20 PM
Sessions says that the Input Ring Gear should offer more resistance when rotated counter clockwise than clockwise.
On mine I don't really feel any difference....
Is this a big deal?
z
Old 03-29-2013, 09:24 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
are your frictions wet or dry? Dry frictions offer less resistance to the test.
try same test with output shaft, one direction more easy to spin than other
Old 03-30-2013, 11:36 AM
Thanks Crosley!........Yeah..just put the pump on for a end play test.....and the output shaft turns a lot harder one way than the other.....also the frictions were wet......soaked em a LONG time while I was rebuilding it.......z
I Need input on gear ratio & tire size TX512 Transmission - Rearend 6 07-07-2011 04:38 PM
TH-350 Sun gear snap ring + shift lever channel score marks 1969ChevelleGuy Transmission - Rearend 3 02-09-2011 09:53 PM
700r4 outer speedo gear not turning? John Fabris Transmission - Rearend 8 05-13-2006 11:43 AM
Ring gear size for 700R4 to 350 V8 in my 39 rwruther Transmission - Rearend 1 12-20-2005 10:08 AM
What ring gear works with 700R4 & 350? rwruther Transmission - Rearend 1 12-19-2005 08:41 PM
