T-350 Intermediate clutch stack clearance - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-02-2013, 03:25 PM
pricesgarages's Avatar
i agree with Crosley use the thicker steels and the wave plate
  #17 (permalink)
Old 03-02-2013, 09:54 PM
Would double stacking 2 steel plates be such a bad idea?
  #18 (permalink)
Old 03-03-2013, 11:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
stacking steel flat plates is fine. Stacking frictions or waved steel plates is not.
I stack flat steels often in drag race transmittins for stock automatic racing. You reduce friction count in clutch packs , as eggzample = a low - reverse clutch in a T-350 or a T-200 . We run 1 or 2 frictions only. We stack up steel plates to set clearance
  #19 (permalink)
Old 03-05-2013, 07:33 AM
I couldn't image stacking steels being a problem if your trying to close up that much slack. If a standard steel measures .068, and your after .050 - .060 of stack clearance, my question would be, "how did you get that much slop in the intermediate stack"?
Well, this could be how. ..........I had the intermediate piston machined to .970 (thanks B&M!), which was in a 2 friction stack that originally measured 1.184 (keep in mind that .992 is the standard thickness of a 3 friction stack from GM. So I measured my current 3 clutch stack with the .970 cut piston. I tossed a extra standard steel in this stack which adds .068, plus the .050 feeler gauge measurement. .118 of total stack clearance, I could leave the extra steel in the stack and be happy with .050, but I am not. If I machine another 6 cylinder piston down to 1.026, and remove that extra steel, I should be left with .060 of stack clearance. Instead of adding extra steels, thicker steels, split cut steels behind piston, etc., I am getting my clearances cut down by just machining a larger piston. So my question now is, does shooting for .060 of clearance a safe bet? Keeping in the .050 - .070 of intermediate stack clearance.
  #20 (permalink)
Old 03-05-2013, 03:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes, that'll work fine.
Were (are) you using B&M's steels and frictions, when you got the too-wide intermediate clearance using the 0.970" piston, or are they from somewhere other than B&M?
  #21 (permalink)
Old 03-05-2013, 04:38 PM
Yes, I was using B&M's transpak kit with frictions and steels. I been meaning to call B&M and ask them why. There is a pdf file you can download from B&M http://bmracing.com/?wpsc-product=tr...0-375b-and-m38 with instruction on building and modifying your TH350. Has blueprints on machining all the clutch pistons. The forward clutch specs were perfect and the direct clutch specs were perfect, except I needed the thin forward pressure plate for the direct clutch stack to get a bit more clearance (I could have maching the direct piston some more, but I was worried that the steel plate might drop too low and bind up). I installed a hardend intermediate sprag, yet B&M never listed this as an upgrade option. I am building a street car, not a drag car. So I figured B&M's transpak should do the trick and be good up to 450hp.
  #22 (permalink)
Old 03-05-2013, 05:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I saved a copy of the instructions from a B&M Transkit- it has the same dimensions, too. On that particular transmission I used Alto intermediate friction and Kolene steels (supplied by the owner) and didn't need to modify the "V8" piston to use them, so my thought are that possibly the B&M parts were thicker.
I wonder if B&M might have used thicker plates in the past and haven't revised the instructions. Seems sloppy on their part if that's the case, but judging by the quality of the photos in their instructions, sloppy may well fit.
  #23 (permalink)
Old 03-05-2013, 06:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
B&M lost their direction years ago from internal and external problems. I would not trust any instructions from them.
Even TransGo in recent years have updated many of their kits instructions for the basic 3 speed trans. Simplified and more clear diagrams
You can run up to .090 clearance in the 2nd gear clutch.
Try to keep the direct piston no thinner than .710 ... You 'may' need a thinner pressure plate for direct clutch with 5 frictions than the plate that came in the trans
The hardened 2nd gear race is likely a re-heat treated OE race. It is re-heat treated to lower the rockwell number so the race is less brittle
  #24 (permalink)
Old 03-05-2013, 08:14 PM
I have done several tranny rebuilds, this would gave been my first performance built tranny. I have had good experience with B&M products in the past. Car craft magazine did an article on this transkit and it sounded great for a performance build. I am sure for what I want, it will work fine. What are the characteristics of the alto frictions vs. the borg warner frictions?
  #25 (permalink)
Old 03-06-2013, 01:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Alto vs. Borg-Warner
IMO you can't go wrong w/any of the major manufacturers, and you'll be just fine using B-W. Kolene steels seem to take a lot w/o problems and I use them whenever I can in most any rebuild. They add to the cost but I feel they're worth it. Others might not agree and that's fine, too.
The manufacturers all offer OEM type replacements along w/heavy duty/high performance/special applications, like the Alto "red" and Raybestos Red Devil and Blue Plate. But within a particular application (stock, heavy duty/towing, hi-po, etc.) they are close to each other in performance by what I have been able to see.
Using a good auxiliary cooler is as important as most anything else for the longevity of an automatic transmission.
  #26 (permalink)
Old 03-06-2013, 05:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Which material from these manufacturers? They offer more than one material friction
With proper set up on the trans and pressure, the common brown paper frictions will take over 500 horse power.
No need for Kolene steels either
The Following User Says Thank You to Crosley For This Useful Post:
jimsmonte80 (03-06-2013)
  #27 (permalink)
Old 03-06-2013, 05:56 AM
It has been over 15 years since I rebuilt my last tranny. And these were just OEM kits, never paid much attention to the friction material brands. I can't even remember where I got those kits. I understand that these high performance friction materials can withstand more abuse and temps, but I doubt that my car will ever see a drag strip (too far away in my state). I already have a large tranny cooler installed and had a shift kit in this tranny from before. Since I am building up the engine, I need the tranny to take the extra power. One problem I always had with this tranny was the delayed 1-2 shift, now I am trying to remedy that with intermediate clearance issues. I still have nothing against B&M, still using their holeshot convertor. But I agree that maybe they need to do some updating of their materials.
  #28 (permalink)
Old 03-07-2013, 09:45 PM
Kudos Crosley on updating the T-350 tech build page. I like the new section on the intermediate clutch.
So now I have 2 intermediate 6 cylinder version pistons measuring about 1.175 that I will have machined down to the perfect size for .060 of stack clearnce. They both are of the later type piston that requires the spring retainier with the staked pistons. But, one has a thick solid contact edge and the other has a thinner contact edge with ribs all around the edge of the piston. Any advantage over one with the other?
  #29 (permalink)
Old 03-08-2013, 07:05 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
Solid contact surface=easy to machine down.....spaced contact surface=not easy to machine down.
  #30 (permalink)
Old 03-08-2013, 07:39 AM
I figured that much on machining the piston. The solid one has more contact area for the wavy cushion spring to rest on, not sure if that even matters. Thanks for the reply.
T-350 Low/Reverse clutch stack, 4 or 5? jimsmonte80 Transmission - Rearend 6 09-28-2016 11:01 PM
TH 400 intermediate clutch piston seal(s) scott67 Transmission - Rearend 1 05-16-2010 10:40 AM
th-350 intermediate clutch problem jeffvega Transmission - Rearend 4 03-02-2009 07:23 PM
Air checking intermediate/direct clutch? Marcus Transmission - Rearend 2 10-23-2004 02:36 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 04:34 PM
