Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 leaking after shut off
Old 01-11-2012, 08:50 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
After Engine shutoff the Fluid drains out of the TC/TorqueConverter back into the Pan. This raises the Fluid level above the normal operating level which is Pan/Case mounting surface. Fluid can then leak at most any bad Seal, Dipstick tube, Detent cable, Shift Shaft, Speedo Housing, Front/Rear.
