-   -   T-350 leaking after shut off (http://www.hotrodders.com/forum/t-350-leaking-after-shut-off-212221.html)
norman o 01-10-2012 05:52 PM
350 trans is leaking after engine is shut off
396chevelle 01-11-2012 06:55 PM
Where on the trans is it leaking from. It's probably your front or rear seals.
SSedan64 01-11-2012 08:50 PM
After Engine shutoff the Fluid drains out of the TC/TorqueConverter back into the Pan. This raises the Fluid level above the normal operating level which is Pan/Case mounting surface. Fluid can then leak at most any bad Seal, Dipstick tube, Detent cable, Shift Shaft, Speedo Housing, Front/Rear.
