T-350 leaking after shut off - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2012, 05:52 PM
350 trans is leaking after engine is shut off
Old 01-11-2012, 06:55 PM
396chevelle's Avatar
Where on the trans is it leaking from. It's probably your front or rear seals.
Old 01-11-2012, 08:50 PM
SSedan64's Avatar
After Engine shutoff the Fluid drains out of the TC/TorqueConverter back into the Pan. This raises the Fluid level above the normal operating level which is Pan/Case mounting surface. Fluid can then leak at most any bad Seal, Dipstick tube, Detent cable, Shift Shaft, Speedo Housing, Front/Rear.
Pinion seal on 8.2 10 bolt rear end leaking, replaced still leaking?! artillerystevens Transmission - Rearend 6 04-10-2011 03:57 PM
Car won't shut off? crash70rs Electrical 12 07-12-2007 07:22 PM
shut off mempis Engine 1 06-02-2005 11:50 PM
My school got shut down Chevy Thunder2 Hotrodders' Lounge 4 03-09-2004 08:19 PM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
