T-350 leaks... pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2009, 12:04 AM
Hey, 79 Camaro with a TH350 here and leaks all over the place.. I recently replaced the stock shifter with a B&M Z-Gate and popped the pan back in with a brand new filter + gasket set.. no leaks from the pan itself but there seems to be a trickle coming from behind the torque converter. I only noticed because reverse decided to stop working and when I checked the oil level it seemed a little low. I uploaded a video onto youtube today when I got under there to check what was going on.. is that the pump on the transmission leaking?
Youtube video link.. CLICK HERE
Old 11-21-2009, 04:38 AM
SSedan64's Avatar
Yep, looks like the Pump seal where the Converter hub goes in.> http://th350.netfirms.com/browser.htm
Old 11-21-2009, 08:23 AM
I agree that it is probably the seal but while you have the converter out take it to a local converter shop and have it leak checked. A crack in the hub weld will appear the same. It is called insurance.
Old 11-21-2009, 10:11 AM
Rexnfx's Avatar
Usually, the pump(converter hub) seal will allow the fluid to be slung around the spinning converter. You are probably leaking through the pump gasket and O-ring. Put a wrench on the lower pump bolts and see if loose.
Old 11-21-2009, 10:28 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
normally the pump hub seal will not leak if it is still soft since pressure behind it helps the seal to hold.'
if the pump bushing has moved forward into the back side of the seal , it will leak a good amount. Or perhaps the seal has partially moved out of the pump body... all unknown till the unit is inspected
I'd try the easy stuff first as mentioned here with pump bolts and stuff before removal of the trans and converter
Old 12-18-2009, 10:16 PM
Ok I've decided to finally drop the tranny and get to work. I got a TH350 rebuild manual so I'm hoping that will help. Anyone know a vendor online for the gasket/o-rings/sealer I need? I read it would be wise to replace the converter to pump bushing as well? If I've got it right, the front seal and bushing is at the red arrows I marked in the pic.. should I attempt to replace the gaskets/o-rings in the blue?
I'm really reluctant about bringing the tranny to a shop. One shop said $75 but they were iffy on what the problem was in the first place. Aamco is asking $150 and the guy was friendly and knew all about the transmission. Either way I don't see that logical to pay $140 to install a $10 part I can do myself in 30 minutes. Anyway, your help is appreciated, thanks guys!
Old 12-19-2009, 11:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
replace bushing and check converter hub too.
parts ; 2 , 3 , 9 , 15 (gasket) , 23 ( bolt washer) are leak areas
13, 14 part numbers are sealing rings and #17 lip seal for piston 2nd gear apply... these will not leak outside the trasnmittin
Old 12-19-2009, 12:54 PM
Ok, looks fairly simple to replace looking at the blowup diagram. Anyone know who supplies these parts?
Old 12-20-2009, 01:27 PM
SSedan64's Avatar
All the gaskets & seals come in an Overhaul Kit about $30. The bushing will need to be ordered seperately about $1. Here's a few sites or you can buy them at your local Trans parts house.
http://www.makcotransmissionparts.com/350-350C.html
http://www.transmissionpartsusa.com/...arts_s/598.htm
Old 12-20-2009, 09:45 PM
$30? I'd imagine these were all the parts I needed.. hardly $4 total.. what does that kit include that I really need?
Bushing
pump seal
oring
gasket
washer seals
Old 12-21-2009, 05:52 AM
SSedan64's Avatar
The Overhaul Kit contains all gaskets & seals, internal & external. Just in case you need to replace other seals now or later. If you don't have any other leaks you can get only what's needed.
350 trans leaks tmcadman Transmission - Rearend 4 02-15-2012 12:17 PM
turbo 350 leaks scottponykilla Transmission - Rearend 1 11-19-2010 10:05 PM
350 turbo leaks mike1956210 Transmission - Rearend 2 06-09-2007 11:09 AM
TH 350 leaks and can't find where... Augusto Transmission - Rearend 6 08-29-2006 10:40 AM
Cross leaks in the 4L80 pump. Jason Transmission - Rearend 2 09-28-2003 06:46 PM
