Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 lock-up question
Old 08-08-2012, 11:28 AM
327NUT's Avatar
327NUT 327NUT is online now
Not a trans. guy ....but there are 2 different TH350's, one is the normal TH350 non-lockup like you have and the other is the TH350C which had a lock-up converter. Installing the B&M kit in your trans....if it can be done will do nothing as you don't have a lock-up converter.....nor can you install a lock-up converter in your trans, wasn't built for one. Find a good TH350C, have one built or install a BUILT 2004R OD trans, it's just about a bolt in for the TH350...same length. Do some research also before you make the change.
